starter problem 2012 1200c sportster
Is this the original battery?
What is your battery voltage?
It should be about 12.6 - 12.8 volts for a fully charged battery.
What does it drop to when you turn on the ignition?
What does the battery voltage drop to when you try to start the bike?
If it drops below about 9 volts you may have a weak battery.
Not enough cranking amps left.
Code:
+-------------------+ | READING IN VOLTS | | PERCENT OF CHARGE | | 12.7 100 | | 12.6 75 | | 12.3 50 | | 12.0 25 | | 11.8 0 | +-------------------+
Received 2,189 Likes
