Any chance this could cause the head to crack?
1 Attachment(s)
I made this little bracket to mount this medallion. Obviously it's bolted down tight, and the fact I've tied the two cylinder heads together, could heat expansion possibly cause one of the heads to crack?
I know the intake is doing the same thing but it's in a beefier part of the head. I also know they used to mount the horn using these two holes, but don't know if one side of the horn mounting bracket was allowed to float to allow for any heat expansion. Opinions... Attachment 620459 |
A ton of Sporties have the coil relocation kit, which mounts the bracket for the coil in the same spot and I've never heard of any breakage to the cylinder heads from this. I made my own coil bracket and it mounts the same way, bolted down tight for 3 years and no problems.
Originally Posted by ApehangerSporty
(Post 17075715)
Thanks! |
My top motor mount uses those two locations to hold the engine in the frame. All 86-03 bikes probably too. I would think it's fine.
John |
Originally Posted by John Harper
(Post 17075953)
John |
© 2024 MH Sub I, LLC dba Internet Brands
