Sporty Spittin and Coughin!
Vent Hole
You can check the VOES with a multimeter and vacuum/fuel pump tester as well. The resistance between the leads should switch with a certain amount of vacuum supplied to the VOES vacuum port. I assume "infinity" (open) to some low number (closed) of Ohms. It's basically an on/off switch triggered by vacuum. I still can't see how it's killing the engine, it just retards the spark a tad under load.
I think it's what Chapter Twelve in norman's post refers to.
Are you sure your new aircleaner or gasket is not blocking the "air bleed" port on the carburetor mouth? I don't think anyone has mentioned that yet.
That new aircleaner looks nice, seems they come from my city.
John
John
I just popped it off to check the vent hole and make sure it’s not blocked and I can see right through.
Assuming we are talking about the same vent!
Came back from vacation, slapped on my old AC, warmed up the bike and did some A/F screw adjustments and the bike runs like a dream.
Confirmed with my indie mechanic, the new AC has me either rejetting, putting in a Mikuni or S&S, or just selling the AC.
Do you guys recommend a new carb or should I try a rejet first?
