RK shocks installed
Holy $h!t, finally got decent weather to ride in and what a difference in ride quality and comfort! I think I'm pushing it harder through corners (which is amazing because I push it like a sport bike lol) and it sucks up the bumps, and uneven pavement was no match!
I should have done this a few years ago! Now to do something with the forks. FWIW, I'm 6'1" 250lbs, I used 15W fork oil and 10lbs of air, RK 13" shocks with 1" Lowering kit |
I put RKs on my '93 and I like them. Also, the $80 price tag on eBay was a plus. 😉
Originally Posted by ApehangerSporty
(Post 17251307)
... like a sport bike lol) ... RK 13" shocks with 1" Lowering kit
Originally Posted by lewk
(Post 17252212)
And if you remove the lowering kit, it will definitely steer like a sports bike! At your height, what do you need lowering for anyway. |
I have been a big fan of the RK shocks since I put them on 8 years ago, I run mine with 0 PDI one up and 10PSI two up.
Here is my thread on doing the front end, that made a huge difference too and I would highly recommend it. https://www.hdforums.com/forum/sport...s-install.html |
Originally Posted by HOTLAP
(Post 17252801)
(Post 17255253)
Seemed a bit to plush with 0 psi, so I tried 5, 10, 15 psi on the same road with the same bumps to get a feel for comparison, 10 psi felt best for me. I just have to figure out which springs I'm going to run.
This Front Suspension REPORT may have some information you will find useful. |
Originally Posted by DK Custom
(Post 17255551)
From seeing how you like it a bit firmer on the rear shocks, you probably would be happiest with the RaceTech Springs and some Intiminators.
Same here, can't imagine spending $400 plus on rear shocks when these smooth the ride out so well, unless you're a road racer that needs ultimate cornering. I can grind the lower muffler with these, and that's as hard as I ever push it anyway. Makes adjusting for two up much better, too. Frost heaves that lifted me off the seat with the stock shocks are a gentle bump now. Had planned on doing something with the front, but I can live with just the RK shocks just fine. I read somewhere that 9 ounces of shock oil work better in a Sportster, so tried that (easy enough to add more), and so far it's worked fine with that. Also, with the much lighter weight, used 10 weight, and don't know if it made that much difference, but I like it just the way it is now.
For anyone else considering the change, I've read all kinds of complicated ways, special tools, homemade things, to get the old oil out. I just put one at a time on the bike upside down, lowered the jack (one shock holds an empty bike just fine) and a gentle push on the seat would pump it up and down, squirted the oil out quick - put a tube on it so it doesn't spray all over. Let my grandson do one it was so easy.
https://cimg0.ibsrv.net/gimg/www.hdf...4befb1b073.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
