2017 Iron 883 Front Pulley Size
The Iron 883 for the US uses a 29 tooth front belt sprocket. 40409-04 SPROCKET, TRANSMISSION - 29 TEETH
The International 1200 models use a 30 tooth front belt sprocket-40380-04 SPROCKET, TRANSMISSION - 30 TEETH (INTERNATIONAL ONLY)The US 1200 models use the same final drive gearing as the 883s.
The 883 models also have a lower primary chain gear ratio (the transmission gears are all the same 883 or 1200)
34/57 sprockets on 883, 38/57 with 1200s
Here is a thread with info on a 32 tooth front pulley-
https://www.hdforums.com/forum/sport...-sprocket.html
The boss for the cover bolts needs some clearance, easy to do with a die grinder, takes about ten minutes.
I purchased it for $209.00 ($219.00 now) with the speedo corrector. If you tell them model they will program the corrector for you, plug and play, very simple.
If you put your adjusters all the forward you can use your existing belt. I am going with a smaller rear pulley also, will go from 68 tooth to a 66 tooth.
This is the ebay seller I purchased from.Seller information
sirrom1 (1856 )
100% Positive feedback
Save this Seller
Contact seller
sirrom1 (1856 )
Save this Seller
Contact seller
