Clutch adjust or replace?
Got an 883 this week. The clutch engages at near full travel, and I did an adjustment. Still engages at neatly full travel.
My guesses are a cable slightly too long or worn clutch plates. Your experience welcome. This makes for less than enjoyable shifting.
~john
~john
Coming from owning all metric bikes (8 total in 30+ years) before the Sportster, I can tell you that Harley Davidson's clutch engagement is TOTALLY different. Both my son's '17 Iron and my '17 Superlow clutch engagement seemed abrupt compared to a metric bike. Took a few days to get used to it, but seems perfectly normal now.
And yes, both are adjusted correctly.
Thanks.
Post up your fix for this as I'm curious what you end up doing.
I would adjust at the basket again and mess around with different backed out possitions to see what works for you. I've definitely had different clutch disengagement points in doing so. One thing I've found with the sportster is that the engagement point is very tempermental if both clutch basket adjustment and clutch lever adjustment aren't almost perfect.
