Johnny_bravo00 ~ Mods & Maintanance thread
#41
#42
I al so had this once in the past but I was lucky to get the broken part out with a reverse tap, a tool for removing broken bolts.
johnny_bravo00 (06-14-2019)
#43
#44
#45
#46
I feel your pain.
How did you manage to break it?
#47
Had the wrench on it, wanted to make sure the O-ring was seated properly. Heard the "click" sound and knew immediately I had snapped it. Stood up, almost kicked the bike over. Put the wrench back on to try and loosen it, that's when it came completely apart. Few choice words and a moment of heavy breathing.
Called today and ordered a new cable ($85), not expected to see it until next Thursday/Friday. The best I can do now is get the rest buttoned up and ready for when the cable arrives.
#48
Although I havnt tried to extract the broken stud out of the primary cover, I finished up the belt side of the bike. Forward controls, intake and heat shields are on. Not noticeable in pics but I polished up the external breather drain line coming out of the bottom of the intake. It is a rigid brake line that I plummed into the breather bolts. Originally it had no finish on it, then I painted it, it and hated it. Now she's shiny .
Using a factory intake and the way I am draining the breather tubes. You have to cut off the tubes feeding into the filter. Thought I'd show how I covered them up. A dime is a perfect cover once super glued on. Only adding to the value of the bike...
#49
LOL, i'll try not go crazy on the casing. If the cable threads dislodge it will be a fairly easy fix. Best case scenario...
johnny_bravo00 (06-18-2019)
#50
I’m going to take it completely off to try my best to “finesse” the stud out. If she doesn’t budge.. Well, I hope it comes out. Don’t want to torch it (and hulk smash). Lol
Honestly, I wasn’t even torquing on that bolt. It snapped soo easily in the first place. Not sure if it was just an old fatigued piece..? Or is it simply because it’s a hollow bolt.
