21” to 19” lacing.
Old 07-21-2018, 02:29 PM
Hunter James's Avatar
Hunter James
Hunter James is offline
2nd Gear
Default 21” to 19” lacing.
Hello all,
Hoping someone can provide insight to my current dilemma. I have a 2006 Sportster custom, I recently decided to do a wheel swap from the stock 21” to a 19”. The question I have is if I can use my hub from the 21” and lace it using the 19” rim and spokes? One thing I have noticed is that the hub from the 21” is a staggered eyelet patten, whereas the 19” has an in-line pattern. Does the 21” staggering affect the pattern layout? Both the 19” and 21” use 40 spokes. I tried to lace the 21” staggered pattern hub to the 19” rim with the 19” spokes but when I do so the threads max out on the outer spokes, which then doesn’t allow them to engage the rim.
Is this just a matter of buying new spokes or should the ones from the 19” rim work? I assumed they would but maybe the staggered pattern of the 21” hub plays a role?
Any advice helps!
- Hunter
21” diagram showing pattern of hub
21” rim with hub (notice staggered pattern) also 40 spokes same pattern.
19” wheel before I disassembled (notice the in-line pattern on hub) same spoke pattern with 40.
Old 07-21-2018, 08:14 PM
badmotorscooter80's Avatar
badmotorscooter80
badmotorscooter80 is offline
You must use a hub for a 19" wheel to properly fit.
Old 07-21-2018, 09:39 PM
Hunter James
2nd Gear
I thought that was the case, thank you. If I bought different spokes could I salvage the build, or would you recommend just buying a whole new rim pre assembled?
Old 07-21-2018, 09:59 PM
65Tiger's Avatar
65Tiger
65Tiger is offline
Buchanans can make you any spokes you want, and in a heaver gauge if necessary.
My Dyna has 17" rims on new style hubs and they made me a F and R heaver gauge SS spoke set, posted to me in Thailand, and laced up locally. I simply told them the rim, and hub and they did the rest.
My rims are a bit custom but still no problem
Easy
A bit more expensive if they lace it.....................
Old 07-21-2018, 10:11 PM
Hunter James
2nd Gear
Easy
Right on! I just discovered their website going to call them on Monday and see if they can help me out. Appreciate it!
Hunter James
07-22-2018 06:49 AM
Almond farmer
11-16-2016 11:29 AM
pewter sb
02-03-2012 12:31 PM
arkieollie
04-23-2009 03:23 PM
jackyl
12-14-2008 05:58 PM
Quick Reply: 21” to 19” lacing.
