2013 Sportster (XL1200C) is stuttering at low RPMs
I just bought an XL1200C and my first couple test drives went great. As I started riding it a little more I noticed some stuttering at low RPMs. Once I get to the higher end of the range it runs great. First couple thoughts were to replace the plugs and air filter. I replaced the plugs with some E3's and have not noticed a difference. When I went to the HD store for a new filter I was told that I have a Screaming Eagle filter and am waiting for it to come in but have low expectations about it fixing my issue. I was also informed that it should be mapped and that might take care of it but $300 mapping is something I found out I might be able to do myself. I just need to find out if I have an EFI tuner installed. Which I plan on doing over the next couple of days.
My first question is if it is ok to ride while i get this ironed out? Mostly just short trips, but would like to drive it to HD which is about a 20 minute ride.
Second question is if there is anything else I should be looking at?
Thanks for your thoughts and suggestions
The 2007-2013 Sportsters have little ignition timing advance between idle and 2000 rpms
Something you might try with the Power Vision is the 2018 Sportster stage 1 ignition timing advance-
Stock 2013 Sportster Front-
2018 Sportster Stage 1 Front-
New info
thanks for the info. Not exactly sure how to read the chart. I did find out that I have a stage 1 conversion kit Installed and probably need to have it mapped. Looks like I have a lot of research to do.
Planning to install some HD plugs instead of the E3s I installed earlier and the seafoam I added has made a difference but not as much as I had hoped.
One question I have is if I can use someone else's tuner or do I need to buy one?
If you're trying to maintain slower speeds at lower RPMs (15-20 MPH) it will require feathering the clutch.
