2013 Sportster 48 cranks but wont start
Hey guys, I need some help with my 2013 48:
22,000 miles
2-1 exhaust
Vance and Hines intake
Fuelpak 3 tuner
About 2 weeks ago I rode over to my buddy’s house about 10 miles, went out to start my bike after a few hours and started right up, after about a 1/4 mile, it died. Just bogged down like it was running out of gas. I tried to bump it before I came to a stop but couldn’t get it going, tried to start it once stopped but starter just clicked, ended up towing it home. Put it on the tender, the next morning went out and started right up. Figured I’d go and get some gas. Let it warm up, and rode over to the gas station, it was hesitating the whole time, made it about 3 miles till it just died at a light. Towed it home again. Strap broke on the tow truck and my bike fell over... got it home, figured it wasn’t charging hence it kept dying and wouldn’t turn over (battery is pretty new, need to have it load tested still) went out and threw the new regulator on, but it only cranks and cranks and cranks but won’t start, checked all my fuses with a VOM, all good. Swapped the relays around, nothing. Figured I’d pull out my spare (brand new) CPS, with no change. Reflashed the ECM back to stock, no change. Pulled the plugs and they were wet with fuel, pulled the coil and tested it, from what I’ve read it’s good. Around 3 ohms, but im not getting spark. Tested for 12v to the coil and found out I’m not getting 12v to the coil. I’m pretty stumped here. No codes on the speedo. Made sure everything was plugged in. Thanks for reading any help is greatly appreciated
22,000 miles
2-1 exhaust
Fuelpak 3 tuner
You will only get voltage to the coil (without the engine running) for a few seconds until the ECM detects the engine being cranked.
The coil power comes from the system relay when you first turn the run switch on. When not running, the power is removed from the coil until the ECU
detects the engine is being cranked and the ECU detects compression (slowing down of the crankshaft due to compression)
You may not see spark when cranking with the spark plugs removed.
The ECU will only fire the plugs if it detects compression, the crank shaft slows during cranking on the compression stroke then the ECU will allow spark as it knows where the compression stroke is.
Phase
(TDC compression) is determined by the ECM during startup and, when necessary, while running. No engine ignition events
can occur until the ECM determines the relationship of piston position to crankshaft position.
Phase
suntzuzuzki, I am doing it from an iPhone but the only option I have is to check for updates, I can’t force it to re update, how did you get it to update?
Phase
Phase
What other things could I check? Would it be possible that the coil is bad even tho it ohm’d out okay?
The ECU detects compression in both cylinders when the crankshaft slows down slightly during cranking.
It uses the output of the CPS sensor to measure the slow down.
You might try opening the throttle slightly, maybe 10%, then try starting.
Same as you would normally do for a flooded engine.
