Dudepants Rubbermount Short Chop
#123
Looking good dude. Love the stance. Forgot to tell you an electrical supply house has small boxes you can adapt for your electronics.Check Grainger out too.Mounted above the battery it will fill some of the space that’s in there now. I’m going to run my stock harness with the breakers and fuses. I learned the hard way what parts cost on an earlier build when you fry something. When I tore the bike down I eliminated all unnessary wires I wasn’t going to use.
You’re doing a good job man. You got a color picked out yet?
#124
- with a rubbermount sporty, the swing arm attaches to the rear motor mount. now that i don’t have a swing arm, i’m not sure how to take up the gap left. might try finding some really large washers or something
- wiring - i need to sit down with the stock harness and start disecting what i really need and where it will all go. your tip on the electrical box might do the trick for the ICU and fuses.
- tail light - am i going to mount it to the fender or do a sissy bar? if i did a sissy, it’d be rather short.
- better check that chain line befor i go much further, i’m a little scared it might hit the oil tank
#125
#126
#127
You talk to anyone yet that has a rubber mount rigid about the chain slap? Pat or Joe at LS should be able to tell you weather or not you need to run a roller. I heard some say you need it with more stretch than two”. Looks like when you get chain adjusted a lot of the there now is going away. I don’t know anyone who has hard tailed a rubber mount in my crowd.
#128
These guys have urethane mounts and are alot cheaper than those billet ones.
Their webpage says their mounts will eliminate chain-slap.
https://shop.rycamotors.com/solid_mo...rtster_02.html
hth,
T.
hth,
T.
#129
Received 4,895 Likes
#130
Could start with this thread for reference pictures;
https://www.hdforums.com/forum/sport...l#post15749357
They started in 2016 and are still slowly working on it.
T.
