Riser extension for iron 2017
Good morning RIDERS, somebody could tell me if installing riser extension of an 1 inch in my IRON 883 2017 ABS I have to change the original cables. I would like to just raise the handlebar a little bit without having to change any cables. I get some extension in my country that they say they are for HD 48, will be the same handlebar that iron? Thank you !!
I used these 1.5" risers without changing cables . I wouldn't go taller.
http://www.dkcustomproducts.com/1-5-...dk-15-rsrs.htm
DK Custom (11-14-2018)
Received 3,931 Likes
The riser extensions pictured above will NOT fit your Iron. They are for a 48. The 48 has a different handlebar riser set up than the Iron (and all other Sportsters). You need to get a Riser Extension Kit for your Iron, you can see various choices at this LINK. They are much LESS expensive than the ones for the 48, and can be shipped to your country.
Faemino (11-18-2018)
