2000 Sportster Project
#101
The MoCo has a special tool to put the cups in. They use race when referring to the cups for the installation tool.
https://www.otctools.com/products/st...ring-installer
#102
It’s clean because there were no cups in there to begin with. I was able to knock the top race out. The bottom will not budge. I’m starting to use a chisel to cut it up but it will not move at all.
im assuming the sportsters has cups, a race and bearings.... mine didn’t, although it did have a Honda front end on it...
#103
To remove the cups HD have these tools
HD-39301-A STEERING HEAD BEARING RACE REMOVAL TOOL
HD-33416 UNIVERSAL DRIVER HANDLE
https://www.georges-garage.com/produ...-race-remover/
#104
The picture you posted in post #90 showed a very damaged cup (race). The picture you posted in post #99 showed the frame neck with the cups (top cup at least) removed.
What am I missing?
#105
I'm assuming the sportsters has cups, a race and bearings
1. Front fork stem and lower bracket
2. Seal, lower
3. Bearing cone (2)
4. Bearing cup (2)
5. Seal, upper
6. Front upper bracket
7. Fork stem pinch screw
8. Washer
9. Fork stem bolt
10. Fork stem bolt cap (XL 1200R only)
11. Pinch screw, upper (2)
12. Pinch screw, lower (2)
13. Steering head (part of frame)
TStephen (03-26-2019)
#106
Okay the MoCo seems to use race and cup interchangeably. In the neck will be a cup (race) that the taper roller bearing runs.
2. Seal, lower
3. Bearing cone (2)
4. Bearing cup (2)
5. Seal, upper
8. Washer
9. Fork stem bolt
2. Seal, lower
3. Bearing cone (2)
4. Bearing cup (2)
5. Seal, upper
8. Washer
9. Fork stem bolt
#107
#108
It can be confusing to people because the Outer Race is also called a "Bearing Cup"
Also that pic above represents the later 04-later frame in the bearing area so it looks different than an 03-earlier frame, although they both use the same bearings / races (cups)
#109
#110
