Sportster dual side exhaust
Take a long look at the current system on your bike, assuming it is stock or close to stock. All rubber-mount Sporties come with the entire system supported off the engine unit. There are none with any part of the exhaust mounting off any part of the frame. On the Touring bikes the mufflers can slide fore and aft through the rear mounts on the saddlebag frames, while the rubber they are made of also allows a degree of movement in other directions.
There were a limited number of models of Sporty with a cross-over system, notably the XLCR, but they were all solid mounts. A pal of mine had one - it was much nicer to look at than to ride!
Keep up the good work
Thanks. You plough your furrow and I'll plough mine. Happy new year.
