Sportster tach kit from HD
I also went with the HD analog tach/digital speedometer. (I use sound and tach readings to control shift points and speed.) The unit is a plug-n-play easy install, and the speed readout is large enough to read at a glance. My experience is that this is a better solution than trying to add another gauge.
After a bit of searching....
2 5/8 mini tach mounting bracket fits 04-later xl customs--Part# 69426-04
2 5/8 mini tach-black face 68953-04, or 2 5/8 silver face-- Part3 68986-04
2 5/8 mini tach gauge housing-- Part# 67524-04.
hth,
T.
hth,
T.
Rode in to church this morning and took a good look at my layout on the bars. Truthfully, there is no room for a side by side speedo-tach. So I guess when I upgrade it will have to be a combo. That or remove stuff I have there and don't plan on doing that.
Those with the HD combo's, ever have any issues with bright light visibility? Any issues with reliability either?
https://serviceinfo.harley-davidson.com/sip/service/document/239891?locale=en_US
hth,
T.
