Iron head Engine Noise (normal)
I posted this on another forum, but received less answers.
The bike runs strong and smooth. I am aware that the Ironhead is noisier then most and that my bike is 36 years old, which means it will not be as quiet as a new bike. I do want to make sure it is a normal sound to the bike. When I ride it I can hear it, but I do not know where the sound is coming from (yet) or if it is a bad sound. This is my project bike, so if I have to shut her down for a rebuild I am okay with that, but if it is a need to adjust pushrods, primary chain or something else I would rather do that. I will try to add some more videos of the sounds as needed, so if you want a specific area tell me and I will work on getting it where you want.
At that age, could be lots or a combo of things. If it was mine, and the clutch was org, I would start there & replace it & get rid of the grenade "Thinggy", even if it don't git rid of the noise, that's something that needs to be done anyway,so nothing is lost there, and it give you a "starting point". Regards "Big E"
https://www.hdforums.com/forum/attac...7&d=1384744519
I restored my 1977 XLH 1000. This is my 3rd Ironhead and I know that sound is not normal. Disregard the "cluch Thinggy"sonce that came into play with the 1986 Evo Sportster. Change your 2 fluids. Ironheads use straight 50, 60 or 70 weight mineral oil. HD chain & gear lube is good for the clutch & trans. Check the rear wheel alignment, if off the chain might be misaligned with the sprocket.
BTW that is a nice lloking bike. This is my first bike restoration, but not my first restoration. I am actually close to just shutting the bike down and doing a ground up restoration, but the bike's value is not high enough for that kind of money expenditure, so I may do a partial restoration this year and then in a couple years do a full.
Also I love the forward controls my wife's XLC had and would like to get that for my bike and I see you have a set, where do you find them?
Thank you for the compliment. Took 2 1/2 years to get it there. The forward controls were on it when I bought it but I think they are V-Twin stuff. Now if you're feeling a small kick under those conditions, I would say the chains are too loose. The primary and/or drive chains would make that happen. Just PM me if you want to compare notes.
