Sportster Carb Coughing
Old 01-11-2019, 12:49 PM
Kawickrice's Avatar
Kawickrice
Kawickrice is offline
Received 3,247 Likes on 1,517 Posts
Originally Posted by perki48
I would drain fuel tank and carb bowls and replace with fresh fuel to start with. If that does not work then I would go on to cleaning/rebuilding carbs.
Yeah this
perki48 (01-11-2019)
Old 01-11-2019, 01:00 PM
Kakha Barnovi's Avatar
Kakha Barnovi
Kakha Barnovi is offline
Looks like 2 of us posted same thing at same time.....LOL
Ok. maybe the old fuel affects on caughing, but does it affect on backfiring thru carb?
Old 01-11-2019, 01:07 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,077 Likes on 1,906 Posts
YES!...........fuel not burning creates LEAN mixture.
Old 01-11-2019, 01:22 PM
Kakha Barnovi
Ok sir. I`ll check that out. I will clean tank, empty carb. Then fill up tank and ride
Old 01-11-2019, 01:25 PM
perki48's Avatar
perki48
perki48 is offline
And if that does not work you may need to clean carbs to clear plugged passages/jets..........good luck.
Old 01-11-2019, 02:16 PM
Tileman2692's Avatar
Tileman2692
Tileman2692 is offline
She's running lean. Did you alter exhaust or intake. If so rebuild with CVP kit. Not expensive around 60 or so.
CV performance
Old 01-11-2019, 02:25 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,628 Likes on 1,124 Posts
Yes. Idle/Mix screw is properly set.
How many turns out is "properly set?" Mine's set at about 2.5 turns out, no carb pops.
When was the last time you changed the manifold seals at the heads?
If it sat for a year, very likely some passages or jets have some residue built up, need to clean all those "boogers" out.
Have you tried Seafoam gas treatment? It worked well on my 1991 before I did a complete carb rebuild and replaced manifold seals.
John
Old 01-11-2019, 04:20 PM
halfmt1's Avatar
halfmt1
halfmt1 is offline
Old 01-11-2019, 11:36 PM
Kakha Barnovi
John
I have changed my manifold seals, They are brand new.
Old 01-12-2019, 12:19 AM
hscic's Avatar
hscic
hscic is offline
Coughing through the carb is a sign of the pilot jetted too lean.
Here is a good vid about jetting.and tuning. Shows symptoms of main and intermediate jets too lean and too rich.
It could also be your idle mixture is too lean.
Quick Reply: Sportster Carb Coughing
