Belt Adjustment
Something I never tried before, but if I put calipers on the nut, would the nut be exactly 1 1/8" and the socket slightly larger or is the socket 1 1/8" and the nut slightly smaller? Been doing mechanic stuff since late '60s and never wondered which was which.
Maybe some auto engineer on here can answer that one.
On a similar note I purchased a set of spanners in the '70s when cars over here were imperial.
The 3/4" spanner would not fit the nut used on the bottom bolt of the rear shock absorber and 3/8" would not fit the adjuster on the throttle cable.
A new set of spanners I have purchased do fit.
