Different length forks for sportsters?
Am wondering if there are different length fork tubes for sportsters? Mi e is the 2007L I eventually want taller shocks and better ones, but don't want the rear aspect too high to the front. This thing sits so low my bike jack will not slide under it unless I hold the bike upright, whick makes it awkward and dicey to get on the jack.
I also will be wanting a bit more ground clearance and shock travel, thus the taller and better shocks.
Can longer springs be added to the front? Would most likely only need to come up less than an inch, just planning ahead.
Thanks
Thanks
Thanks
Thanks
Puffy (02-09-2019)
Hope this helps
Progressive suspension fork springs kit
Standard 11-1527 $97.00 from progressive
Heavy duty 11-1552 (my choice) $109.95 from progressive.
Harley-Davidson part number for 08 damper tubes with rings 45925-04.
The damper tube springs are the same length on all models. I couldn’t find them online and bought them from the dealership for around $45 a piece. You might need to replace the fork seals as well. It’s a messy job, but an easy one.
Puffy (02-09-2019)
http://www.tcbroschoppers.com/catalo...ded+fork+tubes
And probably available from a lot of other suppliers but this is the first one that popped up.
Iron Horse 13 (08-10-2022)
Harley updated the shocks and forks on the Sportsters in 2016.
The newer shocks are gas charged emulsion (available in two lengths) the forks now have a cartridge in one fork.
The single cartridge forks are available in two lengths, low and standard.
Shocks are low ~11 5/8" standard ~13 3/8", the standard length also gives you more shock travel.
The standard height shocks and forks should raise the bike about 1 3/4" to 2"
Premium Ride Emulsion Shocks – Standard Height
Premium Ride Single Cartridge Fork Kit – Standard Height
You would still need to replace the damper in your low forks to the longer standard height.
HD Also offers a fully adjustable fork and rear shock-
Screamin' Eagle Fully Adjustable Piggyback Shocks
Screamin' Eagle Fully Adjustable Front Fork Kit
You may also need to change your Jiffy stand to the longer stand from the 1200/883 R models-
Jiffy Stand P/N 49722-08BHP and possibly a longer front brake line.
Drag Specialties also offers a one inch longer or shorter kickstand for sportsters-
https://www.revzilla.com/motorcycle/...ster-2004-2018
