Air Cleaner Upgrade
- These Screamin' Eagle® products are 50-state street-legal for sale and use on all vehicles, including those that are pollution controlled. Complies with the requirements of 40 CFR Part 86, subparts E and F.
DK Customs has good quality products. The 425, 636, V stack mentioned above are all DK products. I believe they also have the 587 and 606. I personally used their 587 with chrome bobber cover. Performed as a high flow AC should.
DK Customs 587 with chrome bobber cover and double filtered external breather bolts
Arlen Ness Deep Cut Inverted AC with DK completely discrete external breather system
Also used Kuryakyn Velociraptor V-stack with K&N filter and DK double filtered external breather bolts
They all performed the same and did not need to retune with change....so for me, it was all about the look. Stayed with the Arlen Ness.
So pick the one with the style you like best...as long as it is a stage 1 high flow AC
DK Custom (03-12-2019)
They also have the one that goes up and between the heads...that seems functional as the oily mist would go thru the breather or go back into the heads where it would be burnt. They did not offer these when I modded my sporty.
http://www.dkcustomproducts.com/stea...-sd-ebs-sp.htm
That has unfortunately not been my experience. If the oily mist doesn't go through (and out) it does NOT go back in all the way. Because of the umbrella valves, in my case it got trapped and accumulated in that area. Then when I am stopped at a traffic light, smoke comes out like a small choo-choo train as the oil boils/burns away.
hscic (03-10-2019)
I have not used it but have done some research. I asked tech support what happens to the oily mist that does not make it out into the atmosphere.
Received 3,939 Likes
