Bitubo rear suspension 1200 Custom
So I just installed new rear suspension on my 1200 Custom -98, I went with Bitubo shocks but I'm a bit confused.
From what I gather the Bitubo WME0 series should have no problem running "upside down", as stated (I assume it's the WME0 version) by DK Custom http://www.dkcustomproducts.com/over...-r-shk-faq.htm
and the decals are indeed "right side up" when the shocks are "upside down", on a Italian forum(https://sportsteridersitaly.forumfre...entry596931858) I saw that Bitubo seems to have put the stickers on like that at first but later switched or there are some models that use it or something, I'm guessing as it doesn't matter which way they go and it's easier access to the rebound setting, they also show one image on the "upside down version" http://www.bitubo.com/Bitubo/cms/ENG.../140-wme5.html
(a WME5, but same shock as WME0 just longer).
I really like the look and easy access to tune the rebound but had to remove the bolt cover the the saddlebag bars, don't really care about that as they will be covered by the saddlebags but anyhow..
Now I have two questions really;
1. I don't really want to risk a test drive until I'm 100% sure, I'm 99.5% now that all is good (have also emailed Bitubo directly but guess I might get a faster reply here if it's completely wrong), so have I understood it correctly that I can run them like this?
2. Other than the very small difference in weight distribution on the swingarm, is there a any difference in performance/handling etc running them one way or another?
Received 3,940 Likes
[QUOTE=LazyEpic;18138540]So I just installed new rear suspension on my 1200 Custom -98, I went with Bitubo shocks but I'm a bit confused.
QUOTE]
Bitubo makes hundreds of different shocks. If you got the shocks from us, they are separated and you can run them upside down with no problem. The only difference, which you will not be able to tell, is the un-sprung weight.
If you got Bitubo shocks from someone else, I cannot say if they are emulsion or separated.
Always feel free to call or email us. We are pretty quick at responding.
QUOTE]
So there are different versions of the WME0 series?
Ok, guess I have to wait and hope the seller or bitubo can get back to me then.
Thanks for the fast reply anyway ☺️
I'm not us based, so didn't get them from you sadly otherwise I would have gotten in contact directly.
By the way, for future reference, we ship world-wide, over 30% of our orders get shipped outside the USA, including all over Europe.
Ah ok, sadly import tax and shipping really add up and being a student I'm on a budget but will keep that in mind for the future.
Self update, just got a response from Bitubo and seems I was correct, they are even meant to be installed like that.
Originally Posted by Bitubo email
Thank you for your e-mail.
We are pleased to inform you that our shocks may be installed in both sense preserving their perfectfunctionality, since Bitubo oleo pneumatic system is equipped with an internal element which separates gas from fluid.
Please, note that our shock HD003WME02V2 is meant to be installed with shocks body oriented to the bottom, but it may be installed also with shocks body oriented to the top. Usually, Bitubo stickers should be always readable from the left to the right.
