Battery Question
I have a 2014 Superlow 1200T. I loaned my battery to a buddy to help him out...When I got the battery back the little thing that the bolt attached to inside the terminal to allow you to tighten the cables down is missing.....does anybody know where one of these can be found?
The screw is M6 with a 10mm AF head. Inside the terminal will be a square M6 nut.
Try a good hardware shop or google square M6 nut. |
Thank you
Again try Ace Hardware you'll be surprised with the stuff you can find there.
If there's any kind of motorcycle dealer near you, they should have some old replaced batteries that could have those nuts left in them, not doing them any good, might give you one. I keep a few from my old batteries, just in case.
Originally Posted by Imold
(Post 18172231)
John |
Thats a good idea. Will do that one when I replace current battery.
Nut retainer
Originally Posted by handirifle
(Post 18172609)
Another way to go is cut head off a 6mm bolt, put it in the battery post hole and slide a nut in there with blue loctite. Won't ever have to worry about looking for that nut again and you don't have to pull out the bolt everytime you want to add accessories, battery tender, etc. Just have to take the nut off. I use a nylok to keep the wire ring terminals tight on the post.
Just lost one this morning, lucky old battery still had them in it.
© 2024 MH Sub I, LLC dba Internet Brands
