Adjustable Shocks From Glide Models
I know everybody has been using the older Road Glide air shocks with much success. What about these adjustable 12" shocks from the newer (2017-2018) Road Glides? From what I've read they have a better ride than the air shocks. My concern is whether or not there's space for that adjustment know. Anybody have any experience?
https://cimg1.ibsrv.net/gimg/www.hdf...46f59fa2a5.jpg |
Originally Posted by sLow5Rider
(Post 18190544)
https://cimg1.ibsrv.net/gimg/www.hdf...46f59fa2a5.jpg However, on a Sportster they do not do so well. See Chart below. You can see a full Rear Suspension Report at this LINK. http://www.dkcustomproducts.com/medi...ock_Report.jpg However, as you can see from the chart above, they are better than stock. But the take off air shocks from a bagger will do better on the Sporty. |
The adjustability is what caught my attention. Looks like the tried and true air shocks is what I'll be going with. Thanks for the info!
1 Attachment(s)
That setup is standard on the 2017 SuperLow XL1200T.
Preload settings from Owners Manual. Attachment 618480 The way I interpret the settings is for a solo rider at 180lbs there would be no preload. So what happens if you weigh 130lbs? There is no adjustment and the suspension will probably have no sag so will bump up on a rough surface. |
They seem to have different part numbers from the touring shocks though. I'm curious as to how it rides but I don't know anybody with a Superlow
© 2024 MH Sub I, LLC dba Internet Brands
