2000 Sportster Nightmare!!
I’ll spare everyone the previous details about this bike. Here is what I’m dealing with now.
i got rid of the old rear wheel setup that was on it and bought a 2000 wheel with 11.5” disk. Well it won’t fit. I can’t get the axle to line up because the rotor is hitting the caliper and won’t let it come forward enough. The old wheel slides right in with the 10” disk.
How can a 10” disk fit in a 2000 swing arm and caliper.
or is something else going on I can’t figure out. Which has been most of this bike.
thanks for your help....
There's not much to figure out, from the center of the axle to the outside of the disk used to be 5" and the one you're trying to put on is 5&3/4", obviously you're going to have to move the caliper 3/4" further away from the axle.
Before you spend a lot of time fabricating or buying a new caliper bracket take the caliper off and try to fit the wheel to see if there are any other fitment problems, if it installs and rotates properly and the belt pulley lines up exactly then start working on a new caliper bracket.
I’ve confirmed the frame serial number is for a 2000 model. Believe me I am not a Harley mechanic. I’m just trying now to figure out if the guy changed the swing arm or the caliper bracket or what.
This is not much fun anymore.... but am still trying to get past some of these rough spots , which seems to be a lot.
Received 4,923 Likes
Inthespiral
08-17-2019 03:22 PM
