Changing primary fluid 09 XL883L
Old 05-15-2019, 11:27 AM
tms71521's Avatar
tms71521
tms71521 is offline
5th Gear
Default Changing primary fluid 09 XL883L
When changing the primary fluid is it necessary to put on a new gasket kit? I do not have a manual-just ordered...but can't wait for it. Doing the oil and primary fluids this weekend
Old 05-15-2019, 11:49 AM
MikeRC's Avatar
MikeRC
MikeRC is offline
I've reused the chain inspection gasket and the derby cover gasket a number of times. You can't really mess up the inspection gasket but be careful with the derby cover gasket when putting it back on. Worst case you pinch it they're only like $1 from the dealer..
tms71521 (05-15-2019)
Old 05-15-2019, 11:53 AM
nevil's Avatar
nevil
nevil is offline
You might want to get the gaskets anyway, since you're doing it this weekend. If you run into a problem like tearing the gasket at least you'll have a backup. Can't hurt to have them in your stock as opposed to in dealer stock.
Old 05-15-2019, 12:31 PM
TStephen's Avatar
TStephen
TStephen is offline
Whew!! I saw the thread title and thought this was going to be a question on what oil to use.
Change them. Why not?
Old 05-15-2019, 12:55 PM
whylee's Avatar
whylee
whylee is offline
The O ring rubber gaskets I sometimes reuse, I have never had a problem reusing them. The paper board gaskets I always replace. Dont forget about the washer on the drain plug. I normally run a flat file over each side for a couple of passes. If it looks flat and clean I feel ok to reuse it. If it looks bent and dinged up, replace it.
Old 05-15-2019, 04:01 PM
tms71521's Avatar
tms71521
tms71521 is offline
5th Gear
No I'm good on the oil...I can even manage to change the oil myself. LOL I've just never done the primary fluid and want to make sure I don't mess it up
Old 05-15-2019, 04:38 PM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,115 Likes on 629 Posts
Might be worth mentioning that if , like me , you have mid pegs , you will not be able to get the bottom bolt out of the clutch inspection cover without removing the left hand footrest bracket . You might want to get rid of those ridiculous Torx button head bolts while your about it . I've just replaced mine which is how I discovered the awkward bolt .
Windseeker
EVO
04-20-2018 08:16 PM
Henry89
03-01-2016 03:26 PM
emperor wurm
11-15-2011 04:10 PM
beasleyiv
03-01-2011 01:08 PM
fendrix
07-10-2009 10:23 PM
Quick Reply: Changing primary fluid 09 XL883L
