Drag bar v original handlebar
Hayley
Hayley Johnson-Bushnell (05-20-2019)
Those are risers. You can change them to move your bar up, back, or up and back. They come in different heights and bends. You can look for a riser that moves your bar to a position that's more comfortable for you, without changing your handlebars. Depending on the riser, and how much you move the bar, you may have to swap out control cables. You don't have to go crazy, as often a 1" or 2" shift will make all the difference in the world.
Personally, if I was going to do a riser swap, I would use something like a Rox riser, just because it's adjustable.
Rox Extended Stem Pivoting Risers For 1" Handlebars
I have them at the optimum angle but it’s just a really uncomfortable ride after 20 mins - mainly on my neck. I’ve ridden 883s before and not had the same; the other possibility is a different seat but mine looks so cool!!!
lunloon
04-21-2010 01:15 PM
