Oil tank cap fix .
Oil tank cap fix .
I've been having the usual issues with my 2004 XL1200 oil filler cap . It wouldn't turn the last 20 degrees unless I fitted a slightly smaller O ring but when I did this it leaked . So I went down to my HD dealership and bought a genuine O ring. I tried to fit the cap but I still couldn't get it to turn those last 20 degrees . What I then did was make a little sanding block and used it to slightly round off the angle on the spiral groove just where it transitions to the lock position. Result , turns all the way and doesn't leak !
The following 2 users liked this post by Midpegs:
Andy from Sandy (05-28-2019),
curtdoelman (07-29-2019)
It's not just mine , there are numerous references to this issue on this forum . I do agree though . I was in a Harley dealership the other day and every new bike that I tried had a cap that popped in and out without any bother. New ones do have ridges on though .
Another update.
I am delighted to report that after a 40 mile run there is not the slightest trace of oil dribbling from around the filler cap . So , rather than mess around with under sized O rings , if your filler cap gets too tight , just get a new genuine Harley Davidson O ring . The little modification I did just helps the tabs in the tank neck make the transition from spiral groove to horizontal groove . Works for me .
Thats exactly what I had to do to mine. I have osteo-arthritis in my hands and I don't have the strength I used to have, so it was getting impossible to open. I could just barely do it when I got the bike, but not at all now. So 2 days afo, I did the same thing, except with a small file. There is still a bit of effort required but easily doable by me now.
Had not looked it up on the forum, but good to know I was on the right track.
Thanks for posting.
Forgot to add, mine has the temp sensor cap on it.
Thanks for posting.
Midpegs (05-31-2019)
The following 2 users liked this post by RANGER73:
Campy Roadie (05-31-2019),
