Removing Baffles
apache snow (06-11-2019)
Received 4,614 Likes
I would suggest getting a pair of stock takeoffs and knocking the baffles out of those. If you like it, fine, but if you don't, cutout baffles don't go back in. If (when?) governments prohibit louder than stock mufflers, it would be be handy to have the originals, too. I got a pair of stock take offs for $25 once. I have a pair of 2000 stock mufflers with the baffles cut out, noticeable performance hit and way too loud for my liking, but they wouldn't fit your 2017.
Anthony - firstly you didn’t say whether you have stock pipes or aftermarket pipes.
If stock I would obtain a used set of eBay - remove the baffles from this spare set. Install and see what you think - if you like keep em on - if not - you can reinstall your own baffled set.
If you have other pipes eg . I have V&H twin slash Slipons here is my experience - I have standard V & H baffles installed and they sound deep and fantastic - the real Harley rumble. I did though have a few months with the baffles removed as an experiment. I absolutely found the sound at tick-over really appealing - loved it in fact. However, the rest of the riding time with the full range of rpms, I distinctly did not like the sound - the sound was hollow and too higher frequency for my liking; the deeper throaty rumble was missing. So - I refitted my standard baffles and the best Harley sound across the complete rev range is now restored. Good luck.
Sorce (06-21-2019)
So, if you're dead set on knocking out the baffles of some OEM mufflers, I strongly suggest that you get a spare set for cheap as others have suggested, and make sure to get the TTI's as well. You're probably looking at around $100 all in.
The following 2 users liked this post by Jackie Paper:
apache snow (06-17-2019),
Sorce (06-21-2019)
