choke has to be on to run
Hello, I have a 2001 Sportster 1200 (stock) Carburetor has been rebuilt. Still will not run unless choke is out all the way. Also pops and backfires out the carb. Compression on back cyl. is 120 pounds and 110 pounds on front cyl. I bought it like this. Thinking just clean the carb. Back spark plug black (I would think from the choke being on) and front one looks normal.
I welcome any ideas. Also low speed jet is a number 45 Thank You
The choke is actually an enrichener, it adds fuel for better cold start up.
If your sportster only runs with enrichener fully out it's telling you it needs more fuel. Maybe bump that pilot jet up a size and see if it helps.
If not it's got an intake leak and additional air is getting in the cylinders, thus requiring more fuel.
RANGER73 (06-18-2019)
Received 4,928 Likes
xlh883.87 (06-18-2019)
