Won't Idle
Setup:
This post is an extension of a previous thread: https://www.hdforums.com/forum/sport...take-leak.html Before I had an intake leak and this appears to be fixed. Current situation:
There does not seem to be any fuel coming out of the AP nozzle when twisting the throttle. The carb has been disassembled and cleaned. Everything seems to be working properly. Has new AP diaphragm. Here is a video of the issue: |
If you aren't getting any gas coming out of the accelerator pump nozzle when you twist the throttle your carb is not clean. Squirting some carb cleaner in a carb is not cleaning it. You have to completely disassemble it and get all the little holes clean
Or you could have a torn accelerator pump diaphragm, but if you cleaned the carb properly you should know that. |
Originally Posted by VAFish
(Post 19081809)
Or you could have a torn accelerator pump diaphragm, but if you cleaned the carb properly you should know that. I appreciate you assuming I just sprayed carb cleaner in it and called it "clean". But I have completely disassembled, inspected and cleaned every component. The AP diaphram is brand new, just replaced it. Helpful suggestions are welcome. Thanks :) |
Originally Posted by Ryant.glasgow
(Post 19081958)
I appreciate you assuming I just sprayed carb cleaner in it and called it "clean". But I have completely disassembled, inspected and cleaned every component. I the AP diaphram is brand new, just replaced it.
Helpful suggestions are welcome. Thanks :) Something is blocking the AP then it is not clean. |
You may think you have the carb clean, but it is not. I've had to pull them apart 3 times thinking I cleaned them every time.
Gas should be coming out of the accelerator pump nozzle when you twist the throttle, but it's not, that is why it is bogging down and dying. You either didn't clean it right, or since you say you have a new diaphragm, you didn't reassemble it properly. Go back take the carb apart and do it again. |
(Post 19081977)
(Post 19081994)
I've done it multiple times, which is why i was thinking it might be something else.
You gotta get gas coming out of the AP. If that isn't your entire problem it is a significantly contributing factor. There isn't that much else there, you are getting gas to the motor because the bike runs and starts. Make sure the little linkages are hooked up right and the plunger is being pushed when you twist the throttle. If they are, then, Pull the cover off the AP use the thin red tip with your carb cleaner spray and make sure you can spray through the AP nozzle. Also make sure the passage is clean and you are getting gas into the AP diaphragm. |
(Post 19082032)
There isn't that much else there, you are getting gas to the motor because the bike runs and starts. Make sure the little linkages are hooked up right and the plunger is being pushed when you twist the throttle. If they are, then, Pull the cover off the AP use the thin red tip with your carb cleaner spray and make sure you can spray through the AP nozzle. Also make sure the passage is clean and you are getting gas into the AP diaphragm. Alright thanks for the help. I'm gonna take it back off and test out the AC pump again. I tested after I first took it apart, and it was working. Is it possible that the bowl isn't filling for some reason? |
(Post 19082047)
John |
Turns out it was my problem. Took the bowl off again and tested the AP, again, and it was working perfectly. Not much gas in the bowl, so it wasn't getting to the inlet for the AP. Tested my pitcock and it was only letting a small amount of fuel through. Swapped it out and it runs great now!
| All times are GMT -5. The time now is 08:25 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
