Evo Carb vs Fuel Injection
I plan to purchase a used evo Sportster. What are the pros/cons of old school carb vs fuel injection? If I get an evo 883 and do a 1200 upgrade, is rejetting carbs easier than a fuel injection mod?
I've read that fuel injection is easier to start in cold weather. I really don't mind using a choke.
thanks,
Mike
thanks,
Mike
RE: Evo Carb vs Fuel Injection
Fuel injection is much more expensive to tune after you make a change although you can theoretically tune it more precisely. Also, there is evidence now that the stock fuel injectors will only support up to 85 hp. If you plan to build a hot rod sportster over 85 hp, then you will need to replace the injectors (more $$$$ over tuning a carb). Then there is the problem of fuel pump problems on the 2007 models and potentially beyond 2007.
