Neutral issues
Old Jan 14, 2022 | 04:57 AM
mkayx's Avatar
mkayx
When i had that issue at 18k it turned out to be the spring plate common issue
Old Jan 14, 2022 | 04:38 PM
L666's Avatar
L666
Stage IV
Thank you all for the information.
I'll keep monitoring the situation and see how it goes.
Changing the oil in the primary first and see if it gets better.
Old Jan 16, 2022 | 07:32 PM
sportsterpaul's Avatar
sportsterpaul
When you change the primary oil check it for tiny brass glitters, the rivets in the spring plate are brass and that would indicate they are failing.
Old Jan 18, 2022 | 05:39 PM
L666's Avatar
L666
Stage IV
I changed the primary oil 3 days ago.
It was black but no brass glitters and even the magnet on the drain plug was pretty clean.
Jimmy Knuckles
Aug 1, 2015 12:23 PM
Andra2000
Nov 26, 2012 09:26 PM
fxdx-fly-by
Sep 15, 2010 07:31 PM
nathanw
Jun 12, 2010 12:44 AM
1993mooglide
Jun 8, 2009 07:56 AM
