Stator Issue
Old Oct 1, 2022 | 10:10 AM
Stevoknievo68's Avatar
Stevoknievo68
Default Stator Issue
I have a 2021 xl1200x 48 I'm at 17000 miles. At about 15,000 miles my stator went completely dead stranding me on the road. Harley changed it out under warranty. Anyway the other day at a stop light I got a wiff of what smelled like burning ka ka and from what I gather that's the stator going out again. Is there any suggestions on why I'm going thru stators?
Old Oct 1, 2022 | 03:12 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
I have heard of the stator constantly burning out on Sportster models before, the cause was traced to a faulty rectifier / regulator unit.
When the rectifier / regulator was replaced, the burning problem disappeared.
The rectifier / regulator unit acts as a switch, when the battery needs charging it turns on the power from the alternator, when the battery doesn't need charging it turns off the alternators power to avoid overcharging the battery.
It looks like your rectifier / regulator has failed, get it checked out and if it has failed, get it changed for a new unit under the factory warranty. A rectifier / regulator should not fail after about a year, that is a premature failure.
I hope this has helped you.
Old Oct 2, 2022 | 03:13 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If the cable from the stator is run tight around the crankcase it will rub through. If they short poof!
A few of the people I ride with have had the issue.
jrpetrie
Aug 11, 2015 09:15 PM
Pitbull_Dallas
Apr 29, 2015 02:35 PM
Armstronges
Aug 23, 2013 05:45 PM
Takedown
Jul 24, 2011 05:32 PM
