Intake manifold for carburetor on 2007+ EFI bikes
I'm aware that there is a difference in shape on the 2007 and later EFI heads for the intake manifolds, as compared to the 2004-2006 rubbermount sportster heads. As a result, a different manifold is use for late model sportster heads when using a carburetor.
Any recommendations on where to source the correct width manifold for late model heads (which were originally designed for EFI) when using a carb as the fuel delivery source? Any other considerations I'm missing? |
I believe Hammer Performance makes an intake manifold for this application but they are billet aluminum and therefore pretty pricey.
Originally Posted by OCSpringer
(Post 21402882)
For the stock CV carb option I don't think the Hammer Performance intakes are ported. Not a budget option really I guess.
Sporty Parts has a cheaper option. |
(Post 21402894)
Originally Posted by aswracing
(Post 21403242)
You are mistaken.
https://cimg0.ibsrv.net/gimg/www.hdf...f565cc2f60.jpg |
(Post 21402894)
Sporty Parts has a cheaper option. @aswracing , can you confirm that the Hammer Performance intake manifold is US made? Also, I started a a thread here trying to figure out which gasket set to use with EFI heads on an 2004-2006 engine. It seems to make sense for 2007+ gaskets to be utilized, but because there's a non-standard part in the mix (i.e. the Hammer Performance intake for carbureted engines) I wanted to make sure I ordered the correct gasket set. @aswracing , can you help provide insight? |
Originally Posted by FLshovelhead
(Post 21403342)
(Post 21403394)
Absolutely, positively, and I'm not guessing.
Choose your top end gasket set based on what rocker boxes you're using. Although all the bikes from 1991-2022 use the same rocker base gasket (the one between the rocker box and the head), the rubber pieces are very different for the 1991-2003 (3 piece rocker boxes) vs. 2004-2006 (2 piece rocker boxes) vs. 2007-2022 (also a 2 piece rocker box but different). Just spoke to Lorie at Hammer Performance to place an order. |
© 2024 MH Sub I, LLC dba Internet Brands
