2007 XL1200c Wheel Cross compatibly
I just got quoted almost 1000$ to replace a single spoke, do a true adjustment and replace a tire/belt/tube. I find this to be really crazy high and was wondering what wheels are compatible with the 07 XL1200 Custom? It's way cheaper to just buy a nice used wheel... I haven't found a good list online so before I spend money I was hoping the forum could help me out. I heard the 19in wheels are nice
You are talking about the front wheel, right? 2008+ Sportsters went to a 25mm axle so you will want something earlier, probably 2000-2007. A 19" wheel will work in place of your 21", the tire diameter is only slightly different.
Check out https://sportsterpedia.com/doku.php/...k:evo:wheels01
It has been said before that Sportsters handle best with a 19" front wheel.
The front wheel from a 2007 XL883 standard model or an XL1200N 'Nightster' will be a direct replacement on a 2007 XL1200C 'Custom'.
Bear in mind that the Nightster rim is black, so the best option with a 19" front wheel is the standard XL883 with it's chrome rim.
eighteight (04-17-2024)
Rob Roy's Revenge (04-17-2024)
