Vibration
Old Apr 18, 2008 | 03:48 PM
CMORRISM3515's Avatar
CMORRISM3515
2nd Gear
Default Vibration
Im starting to notice a smallvibration in my handle bars while doing slow turns with the throttle closed, it started happening after i got my bike back from the stealer for its 1k service. I dont know if the vibration is normal due to the throttle being closed but it does have me wondering if there is something wrong with the bike. Do you all have any ideas on whats goin on with my bike, or am i just being paranoid.
Old Apr 18, 2008 | 03:51 PM
schumacher's Avatar
schumacher
Default RE: Vibration
paranoid
Old Apr 18, 2008 | 04:17 PM
phatman's Avatar
phatman
ORIGINAL: schumacher
paranoid
X2
I put 200 miles on my 08 custom the firstweek I got it, then we had bad weather so I did'nt get to ride it for a week. When I hopped back on I swore it made noises that it hadn't before. My brother in law assured me that I was just being paranoid, just as you are.
Old Apr 18, 2008 | 04:24 PM
CMORRISM3515
2nd Gear
Cool, thanks for the quick response
Old Apr 18, 2008 | 04:58 PM
Ribcracker's Avatar
Ribcracker
paranoid for sure. I belive part of the 1k service is to reset the idle.This is due to the engine freeing up as it breaks in soto start with idle is set a little higher.
Old Apr 18, 2008 | 08:04 PM
jag1886's Avatar
jag1886
Don't micro manage your Harley. If you want no vibrations get a Cow I Soo Kee.
Old Apr 18, 2008 | 08:09 PM
seldont's Avatar
seldont
What most of these guys are saying is true. I too thought I had vibrations I should not have had on my wife's Sportster at only 300 miles. Everyone finally convinced me it was the nature of the beast. I made mention of it at the shop where I bought it and they finally agreed to check it out. Guess what?? 300 miles and they had to put in new motor mounts. Things are finally as they should be. If it is under warranty and you question whether or not it is okay, ride another one, have someone else ride yours or let the dealer check it for you rather than assume it is okay.
Old Apr 18, 2008 | 09:01 PM
danmo's Avatar
danmo
Worst that'll happen if you ask the dealer to check it out:
"It is a Harley, what do you expect?"
Old Apr 18, 2008 | 10:11 PM
xFreebirdx's Avatar
xFreebirdx
You'd Chit if you took mine for a ride.
Old Apr 18, 2008 | 10:25 PM
hogsport's Avatar
hogsport
Sounds like you are lugging the engine while turningslowly as opposed to having the engine at about 1500 rpm and using the friction zone.
