Help.. Light click sound from starter relay
My bike doesn't start, won't turn over. I took off the seat, and when I start-up all I hear is a light click sound from starter relay. Does this mean I need a new relay, or could it be something else (solenoid?).
Thanks for the help...
1991 1200 XLH
1991 1200 XLH
RE: Help.. Light click sound from starter relay
How old is your battery and what is the immediate starting history of your bike?
After you check the cables get a voltmeter and hook it to your battery. Should read 12 + volts. Turn on the key (lights will burn etc.) should still read 12 + v. Keep an eye on the meter and press the start button. If the meter drops below 8 v, have the battery load tested at HD or Advanced Auto, etc. Rule of thumb, if the engine pauses and then truns over (stock engine), battery is weak but still may last months.
FWIW, I have had similar electrical problems and when I finally got to the root cause, it was loose and slightly corroded battery cables. I disconnectedall 4 points, physically cleaned them with a wire brush and sandpaper, applied dielectric grease, and reassembled everything very snuggly. No problems since - knock wood!
kelton3
04-26-2008 08:51 AM
