Transmission Question
Old May 29, 2008 | 02:18 PM
CalleCula's Avatar
CalleCula
Default RE: Transmission Question
Agree with all other posts, put 1st in before you stop.!!!!BUT if you would forget, release the clutch with witch ever gear you have. Run just half a yard, to get the gearbox spinning. Try to shift while you're still moving. If you're an experienced rider, rev it up a bit at the same time as you release the clutch.
Old May 29, 2008 | 02:56 PM
brainfrz's Avatar
brainfrz
Always be in a gear that you can ride in- even when braking. I find myself engine breaking more then using the actual brakes. But thats not saying that I kill the engine, I gradually down shift.
Old May 29, 2008 | 03:01 PM
Bevo05's Avatar
Bevo05
6th Gear
Thanks for the help....I remember I was not in first when I stopped.
Old May 29, 2008 | 03:06 PM
SportyPig's Avatar
SportyPig
I guess that's why the manual says to shift into 1st and then into neutral. I was in the habit of doing that since I first started riding in 1973, so I never had this problem.
I mostly do it that way, 'cause I can't seem to keep track of exactly which gear I'm in. This is alsowhy I keep searching for the elusive 6th gear.
Carlos Arreola
May 10, 2017 05:55 PM
HDmikie
Jan 23, 2012 03:44 PM
Ludeykrus
Ironhead
Jan 4, 2009 03:28 PM
Curt1953
Jul 26, 2008 07:26 AM
Loch
Apr 25, 2006 12:44 PM
