Bigger front tire on Sportster?
I to would like to go to a larger "tubeless" tire on my 2009 Sporty 1200 Custom.
I currently have a laced 21" wheel and tire and would like to install a alloy 19" wheel with tubeless tire.
My question is: Will I have to modify the front fender?? How will this alter the ride?
Thanks
Frank
Thanks
Frank
Good Morning All,
I have been trying to find out all I can about changing to a mag type front wheel on my 09 1200C. Currently I have a 21" laced … I do not want to make a mistake when I do this.
So … I found a black and Chrome 19" wheel … it says XL FXD Narrow Glide front ends … wheel size is: 19 X 2.15 … from a 2006 … would this fit my needs without modification and what size tire would I use?
Thanks so much for your help.
If by bigger you mean wider, then the best option is to change over to a 19" wheel which can carry a wider tire, like the Std, Low and R models have. The sidewall on the 19" tire is taller than the 21" sidewall so the overall height difference isn't as much as it might seem. That's what I did.
If the OP does want to go completely Forty Eight, he will need a wheel, upper tree assembly off a Forty Eight (black) or newer Custom (chrome), lower tree assembly which includes the axle, and bearings. All this added together is just under $500.00, I have checked. Also you will need a front wheel off a Forty Eight or Custom, depending on the finish. Make sure that if you were to go the Custom route you get one off a new model, I believe this year was the first year that the C went to a Mid Glide setup.
Good Morning All,
