883 to 1200 conversion kit
Neither...go to http://www.nrhsperformance.com/ and get the kit from them...much higher quality and WAY cheaper than either the stealer or JP.
Watch out for the NRHS kit though if you have an 04 or newer Sporty. A few people have had high oil consumption problems after having that kit installed. I was one of them and it ain't fun let me tell ya. The problem never was resolved and there is a thread on the XL forum to this day that has never reached a conclusion.
I've converted many 883 to 1200. Allot cheaper then going out and trading it in for a 1200. Also cheaper on insurance since many states say that anything over 1000cc your insurance will go up. Just don't tell them you converted it. Also the power is a hell of more torque than a stock 1200.
Just get the SE reverse dome pistons and bore the juggs. My local HD dealer did it including all parts and labor for right at $1000.00. This included tuning the carb. Using stock 883 heads it will give you slightly higher compression. And on paper it is still an 883, which means I pay taxes and insurance on an 883, much less. And the enjoyment I get from smoking a BT off the line from what appears to be an 883 is PRICELESS!!!! The lower 883 gearing screams off the line.
The more I ride my bike the more I wish I had a 1200. In traffic going to school the bike just seems to take its sweet time getting up to speed, and I am pushing it quite a bit. This is what I saw on a local Indy shop's website:
883 TO 1200 CONVERSION
SPORTSTER BIG BORE
YOUR CYLINDERS TORQUE PLATE BORED AND HONED TO 1200 SPECS. ON OUR IN HOUSE EQUIPMENT.HARLEY DAVIDSON USES THE SAME CASTINGS FOR 883 AND 1200 MODELS. WE CAN KEEP THE COST OF OUR PACKAGE DOWN BY BORING YOUR CYLINDERS THE SAME WAY THE FACTORY DOES.WE USE THE WISECO REVERSE DOME PISTONS WHICH ARE VIRTUALY THE SAME WEIGHT AS STOCK SO NO REBALANCING IS NEEDED.WE ASSEMBLE YOUR ENGINE USING JAMES STEEL GASKETS FOR A LEAKPROOF SEAL. OUT THE DOOR FOR 799.00 ADD: GLASSBEADED HEADS/ SEATS RECUT/ VALVES RESURFACED/ SPRING PRESSURE CHECKED/ NEW VALVE GUIDE SEALS INSTALLED 150.00 ADD: S&S SUPER E CARB.388.95 MANY MORE OPTIONS AVAILABLE TO MAKE YOUR SPORTSTER GO.
SPORTSTER BIG BORE $850.00
Wonder how good a deal that is.
SPORTSTER BIG BORE
