Type B oil for Type E Required
The owners manual says Type E required for Fork oil, which I beleive is 5W. Is it okay to use Type B oil, which I think is 10W?
I've read some threads that mention the Screamin Eagle oil (15W); I'm just not sure I want to change it that much, but would like it to slow down the brake dive.
Thanks.
Thanks.
SportyPig - how much of a diff were the progressive springs as compared to SE oil?
Considerable difference with the Progressive Springs. The heavier weight fork oil will help some, but nothing like a good set of springs. Just that the oil is a lot cheaper than springs for a bit of an improvement. Especially if it's time to change the fork oil anyway.
I recommend that you get a palm wratchet if you don't have one. That's about the only way you can get the stock springs compressed enough to get the cap nut back on. I don't see which model Sporty you have, but if it's a low, the stock springs have to be compressed about 6 inches to re-install the cap nut. Also if it's a Low model, just go ahead and remove the bars, that will make getting "Jeanie Back in the Bottle" a lot easier.
