painting heat shields
just wondering if anyone has done this. i have vht "flame proof" flat black spray paint. it says it will take 1300 to 2000 degrees but im kind of afraid to try it. i did a test on a spare heat shield and it would look great on the iron(but for how long) but i dont want to mess up my only heat shields that fit. i also have v&h slip-ons that i would do the outer shells the same way.also i only sanded a bit on the test piece. what else could i do? i am also worried about chipping being spray paint.
thanks! any input is apriciated
I used some high temp BBG paint that I bought at Home Depot and I flat blacked the drag pipes on my ’99 XL883. A few people told me that you can’t paint over the chrome and that it will flake off but I just painted them anyway and the paint has lasted for a few years now without any problems so far. A good friend of mine made some heat shields for his bike and painted them with the same kind of high temp BBQ paint and they look good and have held up too! I saw a Harley at Cook’s corner that had exhaust pipes painted GREEN. The guy that owned it said that he just painted over his stock chrome pipes and the slip on mufflers and even though I wasn’t in love with the color choice, the finish looked OK to me. I have no background in painting so I do not know the long term results of painting over the chrome parts but the heat shields do not get as hot as the pipes themselves do and mine lasted for a few years. Good luck with your project and ride safe.
I'm not sure why some folks thnk that chrome is some imaginary diamond type surface or something. If you scuff it real good with a scotchbrite pad and follow the directions, you will have a fairly long lasting finish. Or you could use High temp powder coat, which will last forever. Funny thing is, most of the part houses I find the VHT at, don't carry the primer that is supposed to be used before.
another alternative is to check with a local customizer on powder coating...I want to black out most of my roadster - been eye ballin the V&H duke air breather and black long shots but we're talking 600 - 800 dollars...called a local customizer he said he'd powder coat my heat shields, screamin eagle slip ons, and paint my ham can flat black this winter for $150...
There is no problem painting heat shields the set on my bike was done 3 years ago and still look like new and the advantage of using paint is if you ever scratch them just get out the paint and give them a shot.
The only real trick is to sand them lightly with some 600 grit at the coursest and them use a good Stove Paint like Thurmalox, you have to order it on line but the stuff works great.
I used header/high temp exhaust paint for 30 years and the stuff is crap you are lucky to get a year out of the stuff before it falls off or turns colors, Thurmalox doesn't do that.
