Nose cone timing module
I have one, it works great. But on most bikes it's a waste of money, if you have a bunch of engine work (headwork,compression,cams) you have to have one but if you are a Stage1-2 you don't.
Take and old Thunderstorm Buell as an exeample they had the best Harley built at the time and they used the same ignition module as a Sportster and the SE module was the same also other than they raised the rev limit.
jgcable
09-03-2009 11:48 AM
