Clutch Alert!
  #51
Old 03-25-2019, 06:40 PM
Sewell Steven's Avatar
Sewell Steven
Sewell Steven is offline
Stage III
[QUOTE=SportyPig;6246919]Just a head's up on a real problem with the Sporty clutch. The stock design uses an additional spring plate in the center of the clutch pack. It is a double plate with small springs between the main plate. These plates are all held together by brass rivets.
Those rivets are the weakest link in the entire drive mechanism! My first clutch went out around 25,000 miles. At first I just thought I could adjust it. Could never get it adjusted right. Finally took it to the dealer (it was still under warranty) and they thought they could adjust it. After working with it for about 4 hours, the dealer decided something inside was screwed up. And they ordered everything inside that could possibly be wrong so they could make a quick repair for me.
Two weeks later, the parts were all in, and I was able to make the trip to that particular dealer. Once they opened up the clutch basket, it was a surprise to all. Everyone of those rivets and springs had come out, and had been floating around inside. That had caused the clutch hub and Shell to also be trashed. They had not ordered a shell or hub, and I couldn't fault them for that.
When my last clutch started failing, it was showing the same signs (after 40,000 miles on the second clutch). The signs of the center spring plate coming apart is that the clutch will both slip and drag. In theory that's impossible, but that's how the clutch reacts to those extra parts floating around inside the clutch basket.
The only clutch I could find that doesn't use that same center spring plate design was the HD Screamin Eagle clutch. It replaces that center spring plate with 2 extra friction plates and steel plates. Word of caution if you deside to go this route....that is one freekin stiff clutch! Part of the reason for the center spring plate design was to make the clutch pull easier, and then the outter spring also has to be stiffer on the Screamin Eagle clutch. Between those two, it makes for a very hard clutch pull, also a very reactive clutch. The friction zone is small on the SE clutch. Once you start letting it out, that baby will GO.
This is a picture of most of the parts I dug out from the center spring plate when I replaced it last week.
Hiya fella8
  #52
Old 03-25-2019, 07:25 PM
Sewell Steven
Stage III
Default Sportster XR1200X
Originally Posted by SportyPig
Replacing those rivets would be like polishing a turd. Your still going to have a terrible clutch design.
Hiya sporty, have you ever heard of anyone riding there HD without the middle spring b4 ? Well I just discovered it out a week ago when I opened it to replace my new clutch, "which is another story".
I have been riding it on 8 friction plates & 2 dampener & 7 steel plates for six months now. I have ordered me a Barnett extra clutch kit which eliminates the spring plate for good. What's you opinion on that
  #53
Old 03-25-2019, 07:41 PM
Sewell Steven
Stage III
Default Compression tool !
Originally Posted by wharfrat1959
thanks for all the good info. this is killing me - perfect riding weather, a parked Sportster and nearly empty pockets. it looks like the labor to get this installed is going to run about $140 at an independent shop (2 hrs vs 3 hr @ dealer ). Barnett clutch kit and spring $225 + tax. i'm reasonably handy and will be grabbing the service manual Saturday. what are the pitfalls of trying this myself and what specialized tools should i have?
You'll be needing a compression tool which is a must, second when you pull out the clutch plates inside the very end you may have 2 dampener springs, first 1 looks like a washer which goes in first, second 1 has a slight cone shape to it which goes in second. ( the cone shape side should be facing towards the inside of the clutch hub.) Last of all make sure you snap them rings back in place correctly & double triple check it b4 you start dismantling your compression tool . Good luck with the rest.
ironmike666
03-21-2019 06:20 PM
zyban
12-21-2014 08:08 AM
SANTA DEUCE
01-02-2013 05:50 PM
RidemyEVO
02-27-2010 06:04 PM
pistole
EVO
17
03-19-2009 12:54 AM
Quick Reply: Clutch Alert!
