Help.. push rods tight
Old Apr 5, 2010 | 11:36 AM
strontiumdog's Avatar
strontiumdog
Stage IV
Default Help.. push rods tight
Hi, just changed the cylinder gaskets on my (1990) 1200 sportster.
I've put the Right hand cylinder and the cylinder head back on as per the manual, but the rocker arm cover is really tight and the push rods wont spin. I dont want to star it up like this. Any ideas anyone???? The lifters are at their lowest point?
Old Apr 5, 2010 | 12:15 PM
cHarley's Avatar
cHarley
Did you mark and keep track of the push rods to insure that each push rod went back into the hole it came out of?
Old Apr 6, 2010 | 02:34 AM
strontiumdog
Stage IV
yep, push rods in the right place and right way up and everything back where it came out. I did lap the valves though (very slightly with fine grinding past)???
Old Apr 6, 2010 | 04:24 AM
e6fmf's Avatar
e6fmf
Did you turn the motor over for each cylinder, per the manual?
Old Apr 6, 2010 | 05:43 AM
xFreebirdx's Avatar
xFreebirdx
There are different thickness gaskets. Did you use OEM or aftermarket. Like e6fmf says about the motor........The rods would (could) be tight depending on what stroke the cylinder was on.
Old Apr 6, 2010 | 10:23 AM
strontiumdog
Stage IV
I turned the motor over a couple of times and the pushrods seemed to go to the lowest point (lifters at the lowest point) Ive used a james gasket set(bought it from a harley dealer). Would lapping the valves make any differance ??? (I wouldnt have thought so).
I've followed the maual (clymer & Haynes ) to the exact point but when tightening the rocker arms covers down the pushrods are really tight and will not turn with my fingers (The manual warns about this). Dont really know what to do next (except take it to the shop)???
Old Apr 6, 2010 | 05:38 PM
drum412's Avatar
drum412
Go ahead and bolt the lower rocker down, carefully tighten the bolts just to seat the lower rocker to the gasket and make sure everything is lined up then torque to spec. The reason your having problems is because the tappets still have oil in them causing them to be raised a little. Once you tighten everything up and run the motor the tappets will readjust properly.
Old Apr 11, 2010 | 11:36 AM
strontiumdog
Stage IV
Smile
I bolted everything down and turned the engine by hand. Pushrods now spin with my fingers.
Thanks for the advice.........!
Screamin beagle
Engine Mechanical Topics
Aug 3, 2017 05:16 PM
NamVet69
Jun 11, 2013 08:20 PM
busterman2
EVO
13
Feb 22, 2013 05:31 PM
stevevfd
Aug 12, 2008 09:00 PM
Tltrump
Exhaust System Topics
13
Mar 11, 2008 11:27 AM
