engine or primary noise
Couldn't it be that your primary chain needs to be adjusted? If there's too much play the sound you hear could be the chain hitting the inside of your gearbox, steadily chipping away at it. Look into that.
There are a ton of vids on YouTube on how to do this:
http://www.youtube.com/watch?v=1_sa_S3plos
I'm sure there are how tos on here as well. Good luck and hope everything works out for all of you
Wouldn't hurt to make sure the gas tank mounting bolts are tightened to spec.
Check the gas cap and maybe a couple other things to make sure they are not loose.
Damn....Well, at least I know.
OK. I let the bike run and went all over it, using a screwdriver for a stethiscope. Lots of noises in that engine and primary, but none that sounded particularly bad, and none that matched what I was hearing while riding. Put the bike up on my lift and did more checking. Primary chain adjustment looked reasonable, so I ruled that out.
So then I start looking for loose stuff and after some searching, I was totally surprised to find the rear exhaust flange loose. No retaining nuts or anything. It was rattling around against the rear cylinder, and the exhaust was being held in place with the pressure from the rear mounts. Amazing.
The pipe stayed in place, though, and I've been riding like that for a while. From outward appearance, the retaining hardware hasn't been there for a while. The pipes were on the bike when I got it (used) from the dealer, and it was traded in just the way I got it. I'm guessing the previous owner just didn't tighten the damn things up when he put the pipes on. Or ????
Anyway, after some new stainless locknuts and some Loctite, things are as they should be and the loud rattle is gone. Now all I can hear is the regular Sportster racket!
Thanks
Thanks
sorry if it seems like i just hijacked someone's threed..im not sure of the rules.but my question is the same as here and im afraid to f*k up my motor.my motor has noise also.not knowing anything about my xlh1000. it sounds like there is no freakin oil in mine its so noisey.. it seems like it might be the generator but then it sounds like its coming from the pistons. im afraid to ride it. i see everyone says its the nature of the beast but hell i don't want to f*/k it up... i dont have a video camera to video it. and no friends to stop by and check it out..any help would be great... and again sorry to steal from someone's threed.. thanks
your not alone being worried about the engine noise on the sporster, mine is 883 with 1000 miles on clock and having converted [ i think] from a honda shadow, quiet and smoothe, this is a shock.sounds like a bag of nails churning around in a lawnmower....i know you guys say its normal.... but wow what a shock....as for the bike its magic, rough, agile, full of soul, bum aching, fun.
Get used to it I hear yoy say. ok as long as it is ok???? Shame it spoils the harley sound though....put other exhausts on , ok in time, only 2 days old....
Pete
Pete
I posted almost this same question maybe 2 weeks ago. Many on here said it's just the nature of the beast and these bikes are just loud and make noise. I came off of an 02 ninja and was not used to any bike noise lol. So to be safe I took it to a dealership where I didn't buy the bike and had their tech look at it and take it for a ride and said it's normal and get out and ride...
