Turn signal mounting stud
The stud on my rear left turn signal that mounts the signal to the bike is bent. Because of this, I need to order a new one. Is this a part that Harley would likely have available at a dealership? Or is this something I have to find online or somewhere else?
I plan on calling them in the morning, but in the mean time I'd appreciate a heads up. Also, in order to avoid sounding like a complete idiot, does this part have another name or is that basically it? |
What year? If it's a stock piece I may have one. Maybe post a pic of it.
2009 883L. Yeah, the stock bolt. I'll take some pictures in the morning.
Howzit
There is a post by a member who had the stud drilled out and replaced,do a search.Could be cheaper than a replacement.H.
Originally Posted by Steeler
(Post 6840751)
Yeah, it should be a "through" bolt that runs through the pedestal and is threaded on each end. I have the ones that I took off of my 08 XLN. I assume they'll be the same...?
I can drop one in the mail for you if yours is the same. |
All info indicates that they're all the same. Not sure if that's for certain.
Your local dealer should have a couple in stock.
Alright. I'll take it in when I get a chance. Thanks.
© 2024 MH Sub I, LLC dba Internet Brands
