Mini Apes on Forty Eight - what else is needed?
Yes, your calculations are correct! Of course, if you put taller risers you will have to change cables, eventually.
I'm about to change to some bars with 8" of rise and I only plan on changing the brake cable. So technically the stock cables are a few inches longer than they need to be...not hurting anything.
Just make sure they aren't somewhere they could rub or get caught on something.
Beauty is a matter of individual perception...in my opinion it depends on a lot of other variables whether or not that setup would look good...but it's ultimately you riding it.
As long as you route them properly an extra 2 inches won't matter.
Mini Apes
Reading on this site plus seen some videos on-line about swapping out the handlebars for apes: the Bitwell 8" Chumps work without buying new cables, stock wiring is okay also. The metal brake line needs bent a little and just makes it.'
I rode a 48 with the H-D mini apes, were okay for me, I'm 5'8". I would rather have them a little lower like the Chumps.
Check the net for the videos, will be a big help.
G.
G.
