Raked Frame
Raked Frame
I really like and want the look of a raked frame. I looked at the kits that change the angle and use longer forks, but I just don't like the look. How difficult and expensive is it to cut and extend the down tubes and change the angle of the steering boss? Based on the look of the kits, I want to extend the rake about 14 degrees and use 10" over stock fork tubes.
I've done a few.Its not hard but you need to find a good welder if you cant weld.I cut the neck bend it out to get the rake i want then make up plates to fill the gap.Grind if dont correctly very little putty is needed then prime and paint.Add new tubes so the frame sets level.If you want lots of rake you need to add some to the neck and some to the trees to keep the trail correct so the front end doesnt flop and the bike handles like stock.Look up rake and trail calc. for figures.
Added pics of 3 i did. dyna 38 degs.,77 xl 40 degs.,81 xl 50 degs.
It's also cut under the seat, with an angled piece intalled. This creates the extra rake. I forget exactly what the angle on that piece was though. With the longer downtubes, you need to angle the backbone to match it.
Doing it this way, as opposed to the neck rake, actually gives a better appearance with the higher tank and raked frame. Look at my tank, as opposed to stock set-up. You could also add an extension under the seat to give it some stretch too.
Just to clarify, I did NOT do a tank lift, it's just that it sits at a different angle now, due to the frame job. But it is still mounted to the backbone exactly as it was before. It does give the appearance of a lift maybe, but it is just because of ther angled backbone.
