Drag bars, shorter wires?
Old Aug 1, 2010 | 11:45 PM
misterMagoo's Avatar
misterMagoo
6th Gear
Default Drag bars, shorter wires?
Hi all, I just put drag bars on my 89 Sportster. They look really good, but I ended up with alot of extra wire from the controls. Is it recommended to shorten this or to tuck it? And if I shorten it, where is it best to make the cut?
Thanks!
Old Aug 2, 2010 | 03:36 AM
Guest
Guest
Posts: n/a
Personally, I would tuck it.
Old Aug 2, 2010 | 07:37 AM
Bobber Jake's Avatar
Bobber Jake
I also just put drag bars on and I tucked them. I did not want to cut them and have to splice them back together again. Also I plan on doing a wire tuck under the tank this winter so I did not want to make my job harder later.
Old Aug 2, 2010 | 08:37 AM
chevy94ss's Avatar
chevy94ss
I would tuck them as well. You never know if you switch bars later on down the road and might need the extra length.
Old Aug 2, 2010 | 09:52 AM
Steeler's Avatar
Steeler
Default Howzit
Tuck if you want to change again,bars or risers then it'll be less hastle.
Old Aug 2, 2010 | 11:02 AM
shiftharder's Avatar
shiftharder
I did`nt have to anything with my drag bars - wires are a bit long but nothing I can`t live with.
smoOve
Mar 21, 2022 09:17 PM
fuel injected
Jan 18, 2013 11:52 PM
cornishman
Jan 11, 2010 07:21 AM
eazyrider
Sep 14, 2009 03:13 PM
08blacksporty
May 21, 2009 11:00 PM
